Sponsored by: CARiD
Petronix distributor wiring
Old May 1, 2017 | 12:42 PM
Shiftonthefly1's Avatar
Default Petronix distributor wiring
I got a new Petronix distributor and coil. After reading the instructions they seem a bit vague and universal. This model eliminates the external amp module. So only two wires to hook up. Looking at the old wiring it looks like I can wire this thing directly to the old 2 wire plug (white w black stripe and plain white). From the looks of it they go directly to the old coil.
So is this all that's needed for the ECM to fire the injectors? This seems too easy. I feel like I'm missing something.
Old May 1, 2017 | 10:11 PM
XCELLER8's Avatar
yup...too easy ..but true.....my understanding is that the "2 wires" go directly to the coil.....eliminating the oem amp module, the injectors receive their signal from the other feeds off of the coil....the ones that go thru the resistors in the old hard electrical tape....lol
I hope all goes well and you get all the bugs worked out.....I'm ordering mine next week
Old May 2, 2017 | 03:24 PM
fishEH's Avatar
Which Pertronix dizzy and coil are you using?
Old May 3, 2017 | 12:04 AM
XCELLER8's Avatar
I'm going to order the "D175510" distributor and I already have the 40011 coil
Old May 3, 2017 | 10:15 AM
That's the one I got too. The other option still has an external ign amp module. So I figured I'd do away w such a common failure part.
Old May 3, 2017 | 09:21 PM
XCELLER8's Avatar
do you know if the Pertronix can use oem rover or lucas caps and rotors or if it's Pertronix only ?.....just planning ahead for spare parts othe shelf
Old May 3, 2017 | 09:35 PM
That's a good question. I'll open it up and check it out. Only thing I can do with one arm anyways.
Old May 9, 2017 | 10:28 AM
I can't see any difference between the Lucas cap (right) and the Pertronix
Old May 9, 2017 | 02:40 PM
mollusc's Avatar
Looks like there's a locating tang on the left cap that I don't see on the right one -- unless it's off the edge of the photo at the 3 o'clock position.
Old May 10, 2017 | 10:08 PM
XCELLER8's Avatar
well...that good and scary all at the same time.....lol !
