Sponsored by: CARiD
Please help!!! discomike, elemental ... anyone!
Old Apr 5, 2008 | 03:31 PM
bigbluerover5's Avatar
5th Gear
Default Please help!!! discomike, elemental ... anyone!
2003 disco II 81,000
I've been reading posts for hours and hours and hours, so I decided to see if you guys would help me.
Here goes. A couple of months ago ses light comes on. A few days later, I noticed a very slight skip in the engine. Most people probably would not have even noticed this skip. But it got worse to the point of feeling almost like it dropped a cylinder or something. At this point, check engine light now flashing. No dealer in the immediate area, so I'm on my way to the nearest hook line and sinker mechanic shop (sunliner). Charged me $85 to tell me they wanted to charge me $1200 to change plugs, wires, o2 sensors, air filter, all coil packs, fule filter and do an injection servicing. The diagnostic showed misfires 2 and 3, multiple misfires, bank 2 sensor 1, etc... ... paid the 85 and left.
Went home and changed plugs and wires after talking to the service manager of the dealership that i got the rover from over the phone. No luck. After reading several posts, changed o2 sensors, went ahead and did all 4 for the hell of it, bad idea, got laid off the next day!
anyway, this fixed it, or so i thought. It is now a month later, the light is back as well as the skip, and getting worse just as last time, but now no income and no backup car.
here are the codes:
0150, 1590, 0174, 0302, 1174, 0159
checked the o2 sensors at the dealer with car running, values seem to be correct and consistent. I'm thinking maf, or vacuum leak, or a million other things, but now i need a real mechanic to help diagnose correctly the first time because money is extremely tight, but I need my car.
any help would be spectacular ... by the way this is my first rover, hopefully not my last, but i am getting prett frustrated
thanks guys
Old Apr 5, 2008 | 03:34 PM
5th Gear
Default RE: Please help!!! discomike, elemental ... anyone!
forgot to mention, not that it matters, but I too encountered the 3 amigos 3 weeks after purchasing the car with no warranty (didn't know anything about rovers at the time, stupid me) and they have been hanging out with me every since.
Old Apr 5, 2008 | 03:37 PM
Call me.
303-862-7680
Colorado before 8 pm
Old Apr 6, 2008 | 05:03 PM
5th Gear
found some new symptoms .... when i give the gas a quick tap i can hear very disctinctly a sucking noise which i seems to be coming from the airbox, kinda sounds like an old carburetor when it sucks air and needs to be adjusted. there is also a puddle behind the car beneath the muffler everytime i run the car, can't really tell what it is, but it does smell a little like gas, i just can't tell for sure
discomike ... i have cleaned the airbox and replaced the air filter, i have also tightend the seal between the airbox and where the maf is and then i taped around it pretty heavily just to be sure there was no leak
i also cleared the codes, no codes have come back but car still running like crap. I also haven't actually driven it, i have only started it up in the driveway and let it run for a few minutes, which is how i discovered the puddle
i think that is it so far.
Old Apr 6, 2008 | 08:41 PM
5th Gear
mike had asked me if i had noticed the transmission feeling like it was searching for a gear, specifically the higher gears ... well i drove around today to see if i noticed anything, and i am pretty sure it is doing what he was describing ...
anyone know what this means?
Old Apr 7, 2008 | 12:08 AM
socalrover84's Avatar
when it does that i normally means your mass air flow meter is shot. the ecm takes calculated load values for transmission shift strategy from your maf sensor and as far as the misfire codes make sure your coils didnt take a crap.
Old Apr 7, 2008 | 08:05 AM
"YUP"!
That puts you one step closer to a new MAF.
Old Apr 11, 2008 | 11:56 AM
5th Gear
ok folks, couple of questions ... any help is greatly appreciated.
i have confirmed that one of my o2 sensors is bad, but it was brand new. I realize that it could have been bad off of the shelf, but my question is .... what could cause an o2 sensor to go after only 3 or 4 weeks if it wasn't bad off the shelf?
2 more questions?
what would a bad maf cause? (could it cause the truck to "burn up" o2 sensors)
and
where can i get an maf ... is there anywhere that i could get one today?
thanks everyone
Old Apr 12, 2008 | 08:54 PM
roverguy7's Avatar
does it ever backfire? if it does its a mass air, or a very large intake leak. ive never seen a 150 code, aftermarket sensors?.. how did you confirm the bad o2 sensor... dont worry about the coils, theyre fine. check the hose comming off the intake tube, to the IAC valve and then past the throttle body, make sure its not craked or broken.
[/align]
Old Apr 14, 2008 | 03:45 PM
Don't worry about what may have caused the 02 to fail, by the way, what is the exact fault code? Did you replace all 4 02 sensors?
BethS
Jan 6, 2013 11:30 AM
willrok13
Jan 31, 2010 09:34 PM
hiljak
Jun 25, 2007 12:37 PM
rravenn13
Jun 15, 2007 04:32 PM
DiscoveyII Driver
Jun 5, 2007 07:35 AM
