Sponsored by: CARiD
Plug recommendations on a 1998 D2
Old Feb 23, 2019 | 06:20 PM
dialtonehero57's Avatar
Default Plug recommendations on a 1998 D2
I’m changing the plugs and was looking for a good mid priced plug. I currently have Motorcraft AGS32C but they’re shot
Old Feb 23, 2019 | 07:25 PM
OverRover's Avatar
Just a heads up your '98 is a D1 not a D2.
Re: Sparkplugs NGK 7131
Please don't waste your time or money on anything platinum.
If you need Wires, go with STI-663 > https://www.fcpeuro.com/products/lan...scovery-hls102
Old Feb 23, 2019 | 07:41 PM
that is a newbie mistake 🤣🤣🤣🤣🤣.
My choice on plugs was
thanks for the tip on the wires. Are coil pacs there too?
Old Feb 23, 2019 | 07:46 PM
Best4x4's Avatar
GEMS & BOSCH LR V8's run fine on Platinum/Double Platinum or Iridium Plugs. I've used NGK with great results along with the Autolite Platinum/Iridium Plugs. It's the Bosch stuff you'll want to avoid with the 2x or 4x setup or where the electrode is flush with the insulator.
Old Feb 25, 2019 | 08:56 AM
WaltNYC's Avatar
I use the NGK 7131 (BPR6ES)
Amazon Amazon
and Kingsbourne wires....
Spark Plug Wires for Defender, Discovery and Range Rover
Old Feb 25, 2019 | 09:50 AM
Talking
Originally Posted by WaltNYC
thank you for these suggestions. Got them bookmarked. Once I get the plugs in I’ll reread the codes and see where I’m at. A new wire set maybe next.
Old Feb 25, 2019 | 02:50 PM
WaltNYC's Avatar
Be particularly careful with plug #8 (rear passenger) as the exhaust manifold can impede some of the larger plug sockets and you can wind up cross threading the plug.
Old Feb 25, 2019 | 04:39 PM
Talking
good info. Now if it will stop raining so I can get to work 🤣🤣🤣🤣
Old Feb 27, 2019 | 05:35 PM
Talking
Time to get to work on my plugs and wires. Thanks @WaltNYC for the tips
ok got all my goodies. Times to go to work on this dry afternoon. It’s been a downpour here for more than 48 hours.
Old Feb 27, 2019 | 05:52 PM
Excellent choice on the wires.
