Proper Drive Shaft & U Joint Maintenance ?
Not to long ago I replaced my front & rear drive shafts with Tom Woods drive shafts and I am pretty sure they were already greased / lubricated properly. I was wondering if i would need to re grease / lubricate them just so they have a little more then usual. I ask this because I get car washes that consist of high pressure under carriage washes very frequently and the fact I live in chicago and winter is coming up so there will be tons of salt on the streets very soon.
If it is a good idea to add a little extra grease / lubricant because of my sistutaion what type of grease / lubricant would be good to use ?
How can I Properly grease / lubricate the Drive Shaft & U Joints ?
vishrb
12-06-2014 04:34 PM
drive, grease, gun, joint, land, lr3, lubricate, lubrication, maintainence, maintenance, proper, range, rover, shaft, universal
