Sponsored by: CARiD
Proper Drive Shaft & U Joint Maintenance ?
Old Oct 20, 2009 | 02:21 PM
ALEXAN's Avatar
Default Proper Drive Shaft & U Joint Maintenance ?
Not to long ago I replaced my front & rear drive shafts with Tom Woods drive shafts and I am pretty sure they were already greased / lubricated properly. I was wondering if i would need to re grease / lubricate them just so they have a little more then usual. I ask this because I get car washes that consist of high pressure under carriage washes very frequently and the fact I live in chicago and winter is coming up so there will be tons of salt on the streets very soon.
If it is a good idea to add a little extra grease / lubricant because of my sistutaion what type of grease / lubricant would be good to use ?
How can I Properly grease / lubricate the Drive Shaft & U Joints ?
Old Oct 20, 2009 | 02:30 PM
hilltoppersx's Avatar
you would use a grease gun on the 3 nipples on the drive shaft. people on the forum argue about what grease is best i used green stuff. fill the joints till new grease is seen coming out of the seals.
Old Oct 20, 2009 | 03:02 PM
ALEXAN's Avatar
I am not that tech savy when it come to working on my car but this time and from now on I am going to try. Is there anyway possible you can show me exactly what you told me to do with pictures if possible thanks
wolfgang528
Defender
Dec 28, 2010 04:25 PM
pearlorient769
Aug 6, 2010 05:51 PM
rarick123
Nov 4, 2009 09:18 AM
disco2adam
Nov 10, 2007 11:02 AM
