Sponsored by: CARiD
Proper wash method for a D2 engine 2004
Old 01-10-2016 | 07:50 PM
petminded's Avatar
Default Proper wash method for a D2 engine 2004
This weekend I played in the mud! Very fun! But the engine is now filthy.
Someone said to use a presume washer to was the engine. And I am quite sure that is NOT the right way to do it.
What is the right way to wash the engine without causing harm?
Old 01-10-2016 | 07:52 PM
petminded's Avatar
Forgot the picture.
Attached Thumbnails Proper wash method for a D2 engine 2004-20160109_124926.jpg
Old 01-10-2016 | 09:14 PM
Discoaddictnorth's Avatar
Looks like you had some good clean fun��
Yes you are fine with a pressure, just not full on at any of the electro ice. Keep it at a somewhat fanned out position and keep the wand moving.
Most people I know seem to just use a local self serve car wash bay and save the driveway cleanup.
Old 01-11-2016 | 08:07 AM
Shiftonthefly1's Avatar
I just did mine. I always use a pressure washer. I usually don't hit the area around the fuel injectors. I keep computers/electronics wrapped in a plastic bag or two.
Old 01-11-2016 | 09:08 PM
petminded's Avatar
Thanks for the input!
I went to the self wash. Turned on the engine and used the low pressure. Seams fine and a ok!
Old 01-12-2016 | 07:40 AM
drowssap's Avatar
Windex should do it
caymandrew
05-17-2013 07:12 PM
EkaInfinitos
05-19-2012 01:57 PM
WaltNYC
01-06-2012 04:33 PM
tailchaser0527
08-24-2007 11:10 AM
JRdisco1
12-22-2005 01:37 AM
