Sponsored by: CARiD
Questions about engine r&r
Old Dec 4, 2013 | 10:13 PM
mudbug308's Avatar
Default Questions about engine r&r
I am changing the engine on my 03 disco. Can anyone that has already done this give me pointers or tips so my kids won't hear me curse or bleed unnecesarily. I have already removed everything I think is needed but not sure if starter is bolted to block or through to tranny. Do the tranny oil cooler lines get in the way? All help and tips are greatly appreciated and thanks in advance.
Old Dec 5, 2013 | 09:07 AM
drowssap's Avatar
once you unbolt the brackets that hold the tranny lines to the oil pan the lines should be fine.
Put a jack under the engine and remove the motor mounts, this will allow you to drop the engine enough to get to the rear top bell-housing bolts.
Athana
Nov 2, 2017 10:25 AM
DavidG
Dec 9, 2016 03:34 PM
wolfgang528
Defender
Dec 28, 2010 04:25 PM
avking
Feb 18, 2009 05:10 PM
