Sponsored by: CARiD
Radio stereo Snap Crackle Pop?
Old May 11, 2011 | 06:07 AM
FireUps's Avatar
Default Radio stereo Snap Crackle Pop?
I have 2 rovers.. an 00 disco and 99 Range Rover... the range rover has the issue much worse but they both have the issue.. The ST icon comes on the screen and the radio makes these snap crackle pop sounds... so loud that you have to shut the radio off. the disco does this once and a while .. same thing with the ST icon but its not as bad or as often as the range rover. The CD XM radio (through the tape deck) work fine. Any ideas whats going on?
I believe that these are stock systems without any modifications.
I found this link but I think this is if you are adding amplifiers and such not the stock system 2008 (08) LANDROVER LR2 Radio / Stereo Installation Kit - Do your next car radio / stereo install yourself!
Old May 13, 2011 | 10:44 AM
Ringo's Avatar
Default Snap Crackle Pop
I'll toss a wild thought here. Loose antenna connection. If the radio is the only portion of your sound system making noise it could be a loose/bad antenna connection. From what you state, your cassette system seems to work fine and I'm guessing CDs sound good too. And this narrows it down to the tuner/antenna.
Old May 15, 2011 | 09:55 AM
FireUps's Avatar
I will give it a try. THanks
Old May 15, 2011 | 11:22 AM
thospb's Avatar
Also check the ground connection for the audio unit.
Old May 31, 2011 | 08:41 AM
FireUps's Avatar
Default Land rover radio
A new pioneer with USB jack in the front went in very well.. I found some very helpful wire color guides online and hocked it up and snapped it in with no problem. event modified the original cover to fill the spaces on the side.. $150 for some upgraded technology is way better then the scam the Rover Radio Guys Claim.
first they never even got back to me concerning the 3 email I sent asking for them to help me with the original head unit. I even emailed the guy in the UK and he stated they the US guys are very busy. Well good for them but they don't get my business. it was $189 plus shipping for them to look at the head unit.. if they could not "fix" it they would give you one they could "fix" for $389 which is much cheaper than $689 from landrover for a replacement head unit.
I say thank you best buy and I will use the $439 to fix my AC
snorunner
Aug 22, 2010 02:38 PM
Ericshere03
Jan 30, 2010 12:12 AM
Pwn777
Sep 16, 2009 06:28 PM
tiredone
Mar 20, 2009 03:09 PM
tornado_735
Mar 1, 2009 04:10 PM
