Range Rover B&W Transfer Box Viscous Coupling
Hi,
I'm new here. Long time Landie owner, formerly a 1959 88' SII, 1971 88' SIIA, 1981 2Dr Range Rover 'In Vogue', current stable1979 109" 3/4 ton SIII pick-up undergoing an exhaustive frame up restortation and my daily driver and source of this query, a 1994 LWb 4.2L Range Rover @130K miles.
My transfer case, borg-warner, is in need of a new viscous coupling. The prices I have sourced are all over the mapPN RTC6044, $600-1200.00. I've e-mailed car cannibal about a used one. But in my quest I have a feeling that a number of different auto makes used this box, a BW 4462 I think, and if I can find a domestic counterpart that uses the same box a good new part might be found for hundreds of dollars less. Does anyone know of other makes using the borg 4462 box as found in the 90-94 r.rovers, and I think 95-02 disco's? Alternatively, a fairly proced parts source? rebuild kit as they seem to turn up overhauled in the UK.
Does anyone have a x-ref list for rover parts that turn up on doemstic brands?
Thanks in advance and I look forward to adding to my knowledge of the type and when able, share some.
Regards,
Scott
Regards,
Scott
You might want to check out this link for a good guaranteed used t/case.
http://www.roverlandparts.com/index....S&Category=280
Mike
Mike
Hi,
Thanks for the referal. I'm not keen to change the box as I have already done the shaft and chain and the link you supplied just indicates a used box, which will likely need the same pricey parts, including a viscous coupling.etc.etc.
0304Disco
Jun 15, 2012 02:00 PM
sanmigmike
Feb 21, 2011 05:28 PM
raid13
May 26, 2007 01:23 PM
