Sponsored by: CARiD
Rear 02 sensor
Old May 28, 2016 | 03:33 PM
landroveruniverse's Avatar
8th Gear
Default Rear 02 sensor
hi!
i need to replace my rear 02 sensors. i have a 99 Land rover disco SD
any tips on how to go about it? they seem pretty plug and play - but wanted to check here before i roll under the truck!
thanks!
Old May 28, 2016 | 03:37 PM
Joemamma1954's Avatar
Plug n play, just remember to put some di-electric grease on the connection and make sure the cable is away from any moving part, like the drive shaft and make sure it will not rest on the exhaust pipe.
Old May 28, 2016 | 03:44 PM
8th Gear
thank you! No clue why my local LR repair place wanted to charge me 700 dollars to do this!
Old May 28, 2016 | 03:55 PM
I replaced all 4 of mine for 140.00. I happen to find brand new set on Ebay from guy who sold his D2 before installing them. Be sure and get the OEM, not aftermarket. Amazon usually has them the cheapest.
Old May 29, 2016 | 02:21 PM
8th Gear
one question - am i going to need something like this?:
I for the life of me can't get the other ones out, and fear i may strip if i keep trying!
Old May 29, 2016 | 09:25 PM
Nothing is showing up, so I don't know what you are asking about.
All mine came out with ease using a 7/8" wrench.
Old May 29, 2016 | 09:29 PM
keoni004's Avatar
Easier to swap out O2 sensors than my first ever oil change. Buy the sensors from a reputable reseller/ebay and knock it out yourself. No more difficult than a tune-up, and a lot easier, too!
Old May 29, 2016 | 09:41 PM
Also, I can't recall if the 99 is GEMS or Bosch? I know if it is Bosch, you want to get Bosch sensors, and the GEMS use NGK(not exactly sure) you might check on this.
Old Jun 1, 2016 | 07:41 PM
ihscouts's Avatar
Both GEMS and Bosch. NAS D1 was discontinued basically June of 99, NAS DII came about in July of 99 and both series had SD models.......
KlamathMatt
Apr 17, 2020 05:27 AM
RITTER
Aug 24, 2012 03:16 PM
stupid
Nov 23, 2008 01:17 PM
jmccollister
Sep 9, 2008 08:50 PM
Morgan
Aug 14, 2007 08:15 PM
