Rear 02 sensor
hi!
i need to replace my rear 02 sensors. i have a 99 Land rover disco SD
any tips on how to go about it? they seem pretty plug and play - but wanted to check here before i roll under the truck!
thanks!
thanks!
Plug n play, just remember to put some di-electric grease on the connection and make sure the cable is away from any moving part, like the drive shaft and make sure it will not rest on the exhaust pipe.
thank you! No clue why my local LR repair place wanted to charge me 700 dollars to do this!
I replaced all 4 of mine for 140.00. I happen to find brand new set on Ebay from guy who sold his D2 before installing them. Be sure and get the OEM, not aftermarket. Amazon usually has them the cheapest.
I for the life of me can't get the other ones out, and fear i may strip if i keep trying!
All mine came out with ease using a 7/8" wrench.
Easier to swap out O2 sensors than my first ever oil change. Buy the sensors from a reputable reseller/ebay and knock it out yourself. No more difficult than a tune-up, and a lot easier, too!
RITTER
Aug 24, 2012 03:16 PM
