Sponsored by: CARiD
rear air suspension disco2
Old Apr 19, 2006 | 12:39 AM
xray's Avatar
Default rear air suspension disco2
Hi rear air suspension is low on disco 2 any help please
Old Apr 19, 2006 | 05:52 PM
4x4guy's Avatar
Default RE: rear air suspension disco2
First of all press the up button to put it in off road mode, check to see if it rises,if so switch off engine and listen for air leaks.If no noise is heard leave the vehicle to see if it drops on its own,if not drive it to check if it returns to normal ride hieght .You can listen to see if the compressor is running this is located on the left side under the floor in a plastic black box.If you know how to you can short the relay in the engine compartment fuse box to make the compressor run ,but only if you know an expert.I do this all the time if i cant get my hands on the diagnostic gear if some one else has it.Also check the air springs to see if they are perished this causes leaks that are hard to detect.Let me know how you get on, Paul in the uk
Old Apr 19, 2006 | 07:33 PM
xray's Avatar
ORIGINAL: xray
Thank you Paul from the UK my cousin couldnt wait and has had it repaired .
A new compressor at a cost of $1400.00 but thanks for the help xray
Old Oct 14, 2008 | 10:50 PM
Charles68's Avatar
Hi,
Rear suspension started sagging again. Right rear seems slightly lower than left, and I'm guessing that left rear deflates intentionally to stay balanced? In any case, pump comes on fine and suspension rises every time. Overnight it lowers again. So does this mean leaky right bag? Is there some way to be sure?
Thanks!
Old Oct 14, 2008 | 11:37 PM
jmrivera's Avatar
ORIGINAL: Charles68
Hi,
Thanks!
I have read that some people have had success in finding leaks on the bags by spraying soapy water on them and looking for bubbles... Cheap and can be done immediately, so I think it's a good starting point... Of course, the bags need to be pressurized...
For reference and it's from RAVE;
"Standard ride height, measured between the tip of
the axle bump stop rubber and the axle, is 61.5 mm (2.42 in)."
Measure your ride to make sure it is where it should be and then you can troubleshoot...
Jonathan
Old Oct 15, 2008 | 10:44 AM
ORIGINAL: Charles68
Hi,
Thanks!
PM me your tele number and I'll walk you thru how and what to check.
TRIARII
Jun 30, 2022 09:48 AM
ljdiscovery
Feb 13, 2016 11:21 PM
disco2003
Aug 30, 2014 10:31 AM
fastrx7man
Jan 28, 2012 12:49 PM
rj95lss
Jun 19, 2009 09:11 AM
