Sponsored by: CARiD
rear airbags
Old May 28, 2014 | 10:52 AM
bartleys's Avatar
5th Gear
Default rear airbags
When my rover is off sometimes the rear airbags go down sometimes not. Have to wait for them to go up after starting .yesterday when we got in they went back down . then ok again today.....Help!!!!????
Old May 29, 2014 | 12:09 AM
tuercas viejas's Avatar
Common fault!
Time for some new air springs!
Expect to pay about $350 a pair from Arnott's.
https://www.arnottindustries.com
T/V
Old May 29, 2014 | 12:49 AM
jhmover's Avatar
Just convert to regular springs and eliminate a lot of headaches.
Old May 30, 2014 | 11:47 PM
Well of course you can BUT consider the down grade.
First you have to re-program the slabs controller if you want to do it right.
If you tow like I do with blood stock they don't like the hard ride on steel!
My Paso Finos weight 1000 lbs each. The air ride springs transmit far less shock to my precious cargo. Let alone the kids in the back who like it as well.
If you want to see how a happy horse on air suspension competes see this:-
Real horse power--Oyez Caballos!
Frey Carriage Company - Catalog: Beekbergen - Apeldoorn 09 by Tim Maloy
And Green Ovals everywhere!
Frey Carriage Company - Catalog: Royal Windsor Horse Show 09 by Tim Maloy
T/V
p.s 2002 D2 250,000 miles on 2nd air spring set and third front prop. Original engine/drive train never torn down.
Old Jun 4, 2014 | 04:58 PM
OffroadFrance's Avatar
Nothing wrong with air suspension and consider how old it is! Even coil springs need changing every 10 years or so as they lose their elasticity also. If the air springs have done 10+ years you are doing well as RAVE recommends they are changed every 5 years. They are NOT a leave and forget item as they do have problems with perforations and compressor problems after 10 years and the best way to keep them good is to raise the SLS and wash them off when you wash the truck. If you need to change them see here: http://www.discovery2.co.uk/Rear%20Air%20Springs.html
I changed mine recently and also painted the location points top and bottom and it only takes a few hours. Personally I like the air suspension and it comes in useful sometimes and also a more refined fast ride on tarmac but if you are doing serious offroad events it's vulnerable to damage. Air suspension is also preferable for heavy trailer towing due to the SLS and I have done a lot of towing, in fact, tens of thousands of miles with loads from 2 tons to 3.5 tons at speeds of up to 80mph.
The other issue is that if you modify the rear suspension in theory your insurance company must be informed otherwise they can refuse to pay out in the case of an accident (as you know insurance companies like any excuse not to pay up) but that's another issue.
Nothing wrong with air suspension and consider how old it is! Even coil springs need changing every 10 years or so as they lose their elasticity also. If the air springs have done 10+ years you are doing well as RAVE recommends they are changed every 5 years. They are NOT a leave and forget item as they do have problems with perforations and compressor problems after 10 years and the best way to keep them good is to raise the SLS and wash them off when you wash the truck. If you need to change them see here: www.discovery2.co.uk / Rear Suspension Air Bags
Old Jun 4, 2014 | 04:59 PM
Sorry about the duplicate post, the internet is playing up this evening.
Old Jun 5, 2014 | 07:58 AM
drowssap's Avatar
that's OK it made so much scene i read it twice
Old Jun 5, 2014 | 08:09 PM
C'est mon plaisir
dylanjacobus
Jul 28, 2013 01:26 PM
Doak
Feb 27, 2007 11:30 AM
tripz
Aug 4, 2006 04:05 PM
freerider712
Jul 12, 2006 11:43 AM
95DISCO
Jun 6, 2005 06:08 PM
