Rear Diff. Replacement
Old 09-03-2007, 01:09 PM
Classic89's Avatar
Default Rear Diff. Replacement
Alright so I am trying to replace my rear diff. I have disconnected the rear drive shaft from the flange at the diff. and taken all the bolts off the rear diff and broken the seal around it, but now it still won't come out any advice on why?
Old 09-03-2007, 03:08 PM
Default RE: Rear Diff. Replacement
What year and model???
Old 09-03-2007, 03:42 PM
Classic89's Avatar
89 Range Rover Classic
Old 09-03-2007, 06:44 PM
I am sorry, as I went back to check your replay, I saw your name, been a long weekend.
So, you have to remove your axle from the end of each axle tube, pull each out 8 or 10"s then remove the diff. Why are you removing it?
Old 09-03-2007, 06:57 PM
Classic89's Avatar
I am trying to remove it because a piece has broken off inside and punched a hole in the back so I am taking it out to replace it.
Old 09-03-2007, 07:36 PM
Classic89's Avatar
and with removing the axle from the axle tubes how would I go about doing what would be the easiest way?
Old 09-03-2007, 09:04 PM
If I am not mistaken, on your, you have a hub plate with 5 or 6 bolts on the eng of your axle, remove them and the axle, whixh is attached to that plate, will slide right out.
cornbreadj
12-27-2014 07:50 PM
dusty1
12-07-2014 01:57 PM
oljohnboy
06-09-2014 10:57 AM
hhalimi
02-08-2012 12:40 PM
Disco2Guy
06-20-2008 10:13 PM
Quick Reply: Rear Diff. Replacement
