Sponsored by: CARiD
Rear Diff. Replacement
Old Sep 3, 2007 | 01:09 PM
Classic89's Avatar
Default Rear Diff. Replacement
Alright so I am trying to replace my rear diff. I have disconnected the rear drive shaft from the flange at the diff. and taken all the bolts off the rear diff and broken the seal around it, but now it still won't come out any advice on why?
Old Sep 3, 2007 | 03:08 PM
Default RE: Rear Diff. Replacement
What year and model???
Old Sep 3, 2007 | 03:42 PM
Classic89's Avatar
89 Range Rover Classic
Old Sep 3, 2007 | 06:44 PM
I am sorry, as I went back to check your replay, I saw your name, been a long weekend.
So, you have to remove your axle from the end of each axle tube, pull each out 8 or 10"s then remove the diff. Why are you removing it?
Old Sep 3, 2007 | 06:57 PM
Classic89's Avatar
I am trying to remove it because a piece has broken off inside and punched a hole in the back so I am taking it out to replace it.
Old Sep 3, 2007 | 07:36 PM
Classic89's Avatar
and with removing the axle from the axle tubes how would I go about doing what would be the easiest way?
Old Sep 3, 2007 | 09:04 PM
If I am not mistaken, on your, you have a hub plate with 5 or 6 bolts on the eng of your axle, remove them and the axle, whixh is attached to that plate, will slide right out.
cornbreadj
Dec 27, 2014 07:50 PM
dusty1
Dec 7, 2014 01:57 PM
oljohnboy
Jun 9, 2014 10:57 AM
hhalimi
Feb 8, 2012 12:40 PM
Disco2Guy
Jun 20, 2008 10:13 PM
