Rear Power window won't move
Hey Guys,
I have an 04 Discovery and the rear window will not move. It has worked before and stuck once. I was able to remove the door panel and work my hand in and wiggle the bar inside to get it to roll up once about a month ago. I tested it many times and it worked. Now it has done it again and I can't move it at all. I would like to try all possible routes before I take it in. The new motor for the window is rather expensive (if that is even the problem. Any suggestions?
Station1
06-01-2018 01:17 PM
