Sponsored by: CARiD
Rear propshaft problem
Old May 4, 2009 | 01:57 PM
ianzx6r's Avatar
4th Gear
Default Rear propshaft problem
Can anyone help me ive got a discovery 300tdi which i have put an one and a half inch lift and it keeps eatting the rear propshaft rubber coupling is there a modification i can done cheers.
Old May 4, 2009 | 02:39 PM
I have a solid 3" lift on my D2, I get better then 80,000 to 100,000 miles per rotoflex.
I think you are doing something wrong, check for a directional arrow on the disc, sounds like you are putting it on in the wrong direction or using a really cheap rotoflex.
Let me know what you find.
Old May 4, 2009 | 03:35 PM
ianzx6r's Avatar
4th Gear
Cheers for the info i will have a look at it at work tomorrow. I think i fitted a britpart coupling last time i will let you know what i find thanks.
Old May 5, 2009 | 06:17 AM
antichrist's Avatar
Britpart has become known for having inferior parts in a lot of applications in the past few years.
Old May 5, 2009 | 03:08 PM
ianzx6r's Avatar
4th Gear
Cheers for your info mike had a look at work at the coupling and found it had been fitted wrong in the past (i just copied as you do.) Fitted an genuine landrover one this time and the right way which helps. Road test home with no vibrations thanks again.
Old May 5, 2009 | 03:16 PM
ianzx6r's Avatar
4th Gear
Cheers tom for your info you are the second person to tell me that at least i know for next time thanks again.
Old May 5, 2009 | 04:10 PM
Glad it all worked out.
Remember, keep all thos grease fitting lubed. Does your front drive shaft have the same issue as out, 3 u-joints and only one with a grease fitting, if that is the case, get those 2 greaseless replaced along with the centering ball before it fails, taking out your transmission.
TRIARII
Jul 27, 2013 06:42 AM
TRIARII
Feb 4, 2013 11:03 AM
TRIARII
Jan 29, 2013 09:25 PM
wcryer
Jun 5, 2008 12:08 AM
AlecH
Freelander
Mar 1, 2007 04:26 PM
