Sponsored by: CARiD
Reliability of Land Rover LR3?
Old Nov 12, 2015 | 11:52 PM
li1308238914's Avatar
Banned
Default Reliability of Land Rover LR3?
My husband is a car salesman and they just got in a 2006 land rover Launch ICarScan Bluetooth Diagnostic Scanner with approximately 70,000 miles in and offered it to me fr $14,000. I would like to know people's true reccomedations. I realize repairs are more expensive but from experience how often are they in the shop? I have a 2006 ford fusion right now and I really want to get something that would be good for us starting a family soon. Resources would help. I have to convince my husband that this is a good idea.
Old Nov 13, 2015 | 08:49 AM
uoflcardfan77's Avatar
You need to check out the LR3 section. There's a lot of information there. Some areas to be aware of are:
1) Compressor for air suspension.
2) Clogged moon roof drains.
3) Warped cowl at windshield (lets water into vehicle)
4) Leaks at A pillar (inexpensive fix).
I've had mine since July and it already had a new compressor installed. Also, when I drove it the AC wasn't blowing cold and they ended up putting in a new compressor. Since then I've had to replace the front lower control arms and tie rod ends. I have front wheel bearing hub assemblies on order as the bearings are starting to grind. Those aren't really problems, just maintenance/repair items.
The one you're looking at probably books for a little more than $14K (mine did) but I paid less than that. Mine had 79K on the odometer. You've already mentioned that you understand repairs will be more expensive (which they are) but even with that I love mine.
Get it checked by a good mechanic and if they come down some then pull the trigger.
li1308238914
Oct 30, 2015 10:23 AM
mkaresh
LR2
39
Jan 7, 2015 03:42 PM
mika514
Dec 23, 2013 08:43 AM
mwindth
Jul 6, 2010 10:38 PM
BoeingBoeing
Off Topic
Sep 25, 2009 11:00 PM
