Sponsored by: CARiD
Removing front passenger wiper arm
Old Aug 27, 2009 | 10:50 AM
x1124x's Avatar
5th Gear
Default Removing front passenger wiper arm
My wife's 03 LR Discovery's passenger side wiper appears to be stripped.
The motor works but the wiper doesn't move. Just jerks a little bit, about 1/2". The nut holding it on seems oblong. I have tried a variety of tools I had on my workbench, but can't seem to get at the nut. Is there a special tool?
Thanks for any and all help!
Old Aug 27, 2009 | 11:59 AM
A small socket will fit right in, try tightening it, if that doesn't work, you might try some epoxy on the hub before reinstalling the arm. If that doesn't work, you will need to replace the arm.
Old Aug 27, 2009 | 01:35 PM
x1124x's Avatar
5th Gear
Thanks Mike,
Do you know offhand what size socket?
Thanks!
Old Aug 27, 2009 | 03:02 PM
I am thinking 3/8th, but why not just walk out and look to make sure.
Old Aug 27, 2009 | 06:32 PM
Disco C's Avatar
Are you trying to tighten the large washer nut? Or did you remove the black plastic plug to gain acsess to the tightning nut?
imike1007
Jul 27, 2012 07:39 PM
antichrist
May 12, 2011 12:33 PM
Disco Mike
May 4, 2011 07:08 PM
jhall2
Mar 8, 2008 07:24 PM
