Sponsored by: CARiD
Replace LR4 Power Window Switch ?
Old Sep 25, 2014 | 08:45 AM
Sean_sterling's Avatar
4th Gear
Default Replace LR4 Power Window Switch ?
2010 LR4 5.0L V8 Power Window Switch
Hello,
I need to replace the window switch part on the drivers side. can you simply use a flat head screw driver and lift the part out to accesss and replace it? The dealer would like $230 to do it but I found the part on line for $54. is it easy for a regular guy to do?
Thank you to all you maters tecs that keep us off roading !!!
Old Sep 25, 2014 | 09:44 AM
Jagfixer's Avatar
You need to buy the plastic upholstery trim removing set from Harbor Freight, that way you will not scratch anything. Just be careful, I would try the prying as it seems similar to a Ford truck switch.
Sean_sterling
LR4
Apr 25, 2017 11:23 AM
elboy0712
Dec 19, 2010 02:48 PM
phillman98
Dec 4, 2010 10:01 PM
