Sponsored by: CARiD
Replaced fuel injectors, now misfire in 1,4,6 cylinders
Old Aug 17, 2019 | 08:34 PM
disconic's Avatar
Default Replaced fuel injectors, now misfire in 3,4,6 cylinders
I have an 03 disco 2. I replaced the fuel injectors but now I have a misfire on cylinders 3, 4 and 6. And the exhaust smells like its running super rich. Anyone know what might have caused this? I triple checked all electrical connections before everything was buttoned up. I should probably note, there were no misfiring cylinders prior to replacing the injectors. I should also probably note that it barely wants to start and idles extremely rough, but when driving around it drives like there it's nothing at all wrong with it and super smooth. Thanks in advance.
Old Aug 19, 2019 | 09:12 PM
disconic's Avatar
For anyone who may also he having this issue I think I may have found what the cause is. When I buttoned everything up I had a few plug wires touching the secondary air injection canisters lines that tie into the heads, and they got a little singed. I will change the plug wires and post the results.
Old Aug 20, 2019 | 01:12 AM
disconic's Avatar
Well it wasn't the plug wires. Installed new ones. Runs great when it's cold then runs extremely rough at idle when warm, wants to die but once I get moving the SES light stops flashing and she drives fine. Anything standing out to anyone? I'm stumped. New coil pack?
disconic
Aug 26, 2019 08:05 AM
Gonzaleasy
Apr 2, 2019 05:48 PM
HBW1020
Sep 1, 2018 09:29 AM
bmeier
Jul 17, 2014 03:25 PM
schneider
Dec 14, 2009 06:27 AM
