Sponsored by: CARiD
Replaced o2 sensors= new codes
Old Mar 26, 2011 | 10:27 AM
ArmyKen's Avatar
4wd High
Default Replaced o2 sensors= new codes
I relaced all 4 O2 sensors on my 2004 Disco II only to have more codes come up. They read as follows: P0150, P0174, MIL ON, MONITRS, 3 Inc, Catlyst, Evap, O2 Snsr, 5 Ready, Misfire, Fuel, Comp, Sec Air, O2 Htr. I used O2 sensors bought from Atlantic British.
Old Mar 26, 2011 | 06:40 PM
You did it backwards, you need a tune up, that means new spark plugs and spark plug wires.
98% of all Land Rover O2 codes are due to the severe need of a tune up, thats why you have the mis fire codes.
Do the tune up, clear the codes and see what, if any, come back.
Old Mar 27, 2011 | 11:41 AM
And recheck your codes, this time send us all your 4 digit fault code numbers so we can help you.
Old May 13, 2011 | 01:24 PM
ArmyKen's Avatar
4wd High
I've been chasing this issue for a couple of months now. I have replaced the spark plugs, O2 sensors, had a smoke test done (no leaks found), eventually replaced the MAF, and cleaned the fuel injectors. The codes keep coming back as P0150 and P0174. I pulled the new spark plugs to have a look and the passanger side plugs are much dirtier than the driver side. I am at a loss.
Old May 14, 2011 | 08:06 AM
Make sure your SAI filter is clean, there is a "how to" in the DII section.
04SSHD
Apr 11, 2012 06:20 PM
ArmyKen
Mar 23, 2011 01:33 PM
Garrett
Feb 15, 2011 06:45 PM
BajaXJ92
Dec 3, 2009 07:43 PM
