Sponsored by: CARiD
Replacing Radiator
Old Apr 27, 2008 | 12:38 AM
vt_big_papa's Avatar
Default Replacing Radiator
I had a local radiator shop re-core and repair one of the tanks for my 97 Disco. I've got it all back together, but need to replace the fluids for transmission cooler, and engine coolant. Never done this before, any suggestions for a Disco Newbie?
Old Apr 27, 2008 | 09:14 AM
Default RE: Replacing Radiator
Buy any of the better green or yellow coolants, mix it 50/50 with water. Consider replacing your t/stat at the same time as well as your coolant recovery bottle if you still have the old black bottle. the black ones are prone to cracking and have been replaced a few years ago with a new white bottle with better seams. You might also consider putting a bottle of Water Wetter or Purple Ice in with your coolant.
As for the tranny fluid, consider draining the rest of the fluid, not changing the filter, and adding as much Dextron as needed, may be 6 quarts or so.
kfx4001442
Jan 23, 2012 09:30 PM
danvlarsen
Nov 3, 2010 08:10 PM
Burncycle
Oct 29, 2009 07:17 PM
VintageEros
Mar 6, 2008 08:48 AM
chrisusvi
Apr 27, 2007 09:48 PM
