Sponsored by: CARiD
right side low beams out? any help please
Old May 21, 2013 | 10:45 AM
filthydisco01's Avatar
Default right side low beams out? any help please
turn my lights on the head lights come on but no dash illumination... the air controls do not illuminate either.... the shift area does illuminate but oddly enough only when i have the headlights off as soon as i turn them on that goes out as well. Also another issue i noticed I had a tail light out so i replaced the bulb which was infact bad but it still is not working with the new bulb. Any input or help would be much appriciated a
Old May 21, 2013 | 11:40 AM
Thank you for your confidence in our Jedi mind powers to view the particular vehicle parked outside your IP address, and determine the year and model. While Rovers share many things, like a reluctance to hold their fluids, a wiring diagram is not one of them.
Old May 21, 2013 | 12:12 PM
I have 2001 disco
Old May 21, 2013 | 12:15 PM
Could it maybe be a relay? All my grounds are fine its just that I was connecting some spotlights and I must have mixed wires then it sparked and now no low beams on my right side
Old May 21, 2013 | 12:27 PM
gprtech's Avatar
Did you check all of the fuses?
Old May 21, 2013 | 01:30 PM
Yes none of them are blown
Old May 21, 2013 | 05:46 PM
Any other possibilities?
Old Oct 19, 2013 | 12:43 AM
Ed1911's Avatar
4th Gear
You wire in a remote starter? I've seen a very similar issue in a 2002 that had an aftermarket remote starter installed.
filthydisco01
May 22, 2013 01:04 AM
ttressler
Freelander
Jan 14, 2012 11:51 PM
chimchongdlight
Oct 2, 2011 05:39 PM
ruffram
Sep 1, 2011 08:15 PM
