Sponsored by: CARiD
Rough idle throttle lag
Old May 31, 2020 | 11:20 AM
Wooduck's Avatar
5th Gear
Default Rough idle throttle lag
2002 disco rough idle , throttle lag , new injectors,coil,plugs and wires,idle air sensor,cleaned throttle body. This is an intermittent problem which started after a transmission fluid change? Even when running smoothly can’t pull trailer? After throttle lag power suddenly comes on strong. HELP I love this vehicle !!!
Old Jun 1, 2020 | 12:04 AM
JUKE179r's Avatar
Seems like from your two older posts you’ve had this problem for years now.
Take off the intake air controller (IAC) on top of engine, Spray some carb cleaner into both air passages of IAC, use an old tooth brush and rag to clean inside good, reinstall, plug in connector and go for test drive.
This time, report back your results.
Old Jun 18, 2020 | 05:32 PM
Wooduck's Avatar
5th Gear
Default Update
Replaced IAC and tps no help, cleaned throttle body did not remove, no help then one day it sputtered real bad came back to life and been fine?may replace Gizmo just after air cleaner but expensive ?
Old Jun 18, 2020 | 09:46 PM
Best4x4's Avatar
If it's running crappy you should have pending codes for misfires, O2 sensors, emissions or MAF.
Old Jun 19, 2020 | 04:42 AM
Wooduck's Avatar
5th Gear
Default Codes
Codes come up misfire all 8 cylinders and two codes fuel and air , no specific components,the only thing I haven’t changed is the Mass airflow sensor and the fuel pump?
Athana
May 9, 2018 07:47 PM
mikec205
Jun 9, 2017 06:26 AM
min624
Sep 7, 2014 07:08 PM
psykokid
Nov 16, 2011 07:32 PM
jasons
Jul 30, 2009 08:15 AM
