Sponsored by: CARiD
Safety Chains on a D1
Old Jul 26, 2017 | 02:19 AM
DiscoCam's Avatar
Default Safety Chains on a D1
So I wanted to tow my motorcycle trailer with my D1. And I know this might sound dumb, but I had no idea where to attach the safety chains and I still don't. Looks like there are two latching points on the frame rails in the back, but the chains are no where near long enough to reach.
Any insight?
Thanks
Old Oct 30, 2019 | 08:20 PM
jjh221's Avatar
I made same mistake today too not thinking about it. I'm trying to come up with an easy solution or ill just weld on some rebar or scrap rod to the hitches frame. So far I have not found any attachments that might work. Id use a clevis or a slip hook but both of those will have to be pretty damn big and might come back to same problem. Thought about just getting a couple tie down D rings with U bolts and attaching it to the cross bars of the hitch. So far I think welding on some rod would be easiest fix but not sure how much load it would carry.
Thoughts anyone?
Old Oct 31, 2019 | 10:06 AM
whowa004's Avatar
Getting longer safety chains seems like the easiest and logical solution. That way you are not adding any new points of failure to the system.
Old Nov 1, 2019 | 05:38 AM
jjh221's Avatar
Good idea.
I welded on some rod yesterday till wider hooks arrive. Only issue with long *** chains will be them being really long for other vehicles. I don't think I twist that much slack up.
I agree though I don't feel safe with my addon.
merebel
Mar 9, 2019 02:46 PM
calebbo
Nov 13, 2011 09:41 PM
yloDiscoII
Jan 28, 2011 10:52 PM
malmberg
Nov 5, 2010 12:39 PM
Rovinfool
Aug 26, 2010 04:09 AM
