Sponsored by: CARiD
Search question, Sensor ring
Old Sep 17, 2010 | 08:22 PM
leadfoot's Avatar
Question Search question, Sensor ring
I hate to ask something it has been asked already, so I always try to search first, but how do I search to a combination of words. I am searching for ¨sensor ring¨ I get all sensors and all rings but not specifically both. Sorry for my ignorance. And since I already got this far, my problem is that I am doing the rear brakes and the sensor rings are stuck with rust. I did not order them, so I am trying to get them out. Any ideas? and if I have to order them, I still want to save the hub, do a hammer and chisel will do to break them out of the rotor?
I was hoping to do the job this weekend and now it seems like my LR will be on jacks for days. Very frustrated.
Old Sep 17, 2010 | 09:34 PM
XCELLER8's Avatar
been there, ............you need a BFH , some PB BLASTER...and a lot of patience. I'm going to assume that you want to get the rings out so you can install them in a new set of brake rotors ? ftc1379 is the likely part #( and they are VERY expensive) SO...soak them in penetrating oil for a while you might be able to tap on the studs to help get them out ( if you damage a stud....the threads are 6 x 1.0 metric) tap ( beat ) on the outside of the rotor....wear some safety glasses as the rust will be a flyin' sooner or later they will come loose and you can reuse them as long as you dont bend them . good luck
Old Sep 17, 2010 | 09:45 PM
leadfoot's Avatar
Thanks. At least you gave me hope. I will let them soak overnight in WD40 and try again tomorrow.
Old Sep 17, 2010 | 11:16 PM
leadfoot's Avatar
I went to Walmart and got the PB Blaster. I will let you know tomorrow how it goes. Thanks again.
Old Sep 18, 2010 | 02:35 AM
antichrist's Avatar
http://lmgtfy.com/?q=%22sensor+ring%...overforums.com
Sorry, couldn't resist
Old Sep 18, 2010 | 09:10 AM
leadfoot's Avatar
Thanks, that answers my first question.
Old Sep 20, 2010 | 01:06 PM
leadfoot's Avatar
My wife is still laughing. XCELLER8 recommended a BFH and I thought, humm, it must be some special tool I don't have yet. I did a search on Google and there it was, the most primitive tool, which by the way, did not good to me this time. I broke the rotor in pieces with the BFH and after a lot of bad words my wife suggested using something a little more sophisticated, like a saw. That finally did the trick. Got new Brakes all around now.
Thank you all.
luckyd77
Jan 13, 2014 12:21 PM
wheelgarage
Jan 18, 2012 01:50 AM
leadfoot
Sep 27, 2010 06:37 PM
WIS ROVER
Sep 17, 2010 09:00 PM
XCELLER8
Nov 4, 2009 08:55 PM
