Sponsored by: CARiD
Self Levelling Suspension & ACE
Old Mar 24, 2007 | 10:23 PM
MissionV1's Avatar
4th Gear
Default Self Levelling Suspension & ACE
Hi
I am new to the forum and Land Rover world. I have been reading feed backs on a number of topics andam sureyou may be able to give me a guide note as to were to start.
I have recently bought a a SEII 2002 with full works. Yesterday I tried to resolve a problem with non op electrics on passenger seat by changing the 40 amp fuse. it blew as one should expectwith first move on back rest position change. but... the problem now has multiplied ... it brought up a number of other faults on dash.
Break, ACE and Self Levelling Suspension. Apart from break the other two are amber.
The SLS is the main problem as I pressed the dash button hoping to clear it off,rear suspension went down and now refuses to come back up.
I tried th disconnecting battery to rest but no response. the fuses seem ok I have looked under steering and engine comp unit.
Can you please tell me what can be going on.
The speedo has alsostopped working at the same time but the lights and rev counter are ok
Its (SLS) supposed to rest level at 8-13 miles speed but I assume it cant see this if the speedo is off?
Its the weekend and there is no service dept open in site. I am stuck.
I am hoping its a reset problem or fuse/ relay?
Many thanks
Please let me know what you think
Al
Old Mar 25, 2007 | 11:48 AM
Default RE: Self Levelling Suspension & ACE
Al,
let me know this morning if your SLS is back up and operating.
Mike
Old Mar 25, 2007 | 01:38 PM
MissionV1's Avatar
4th Gear
Hi Mike
Thanks again for the call and all the advice yesterday. You havebeen a great help.
I went over and disconnected the -ve, rechecked the fuses and looked for that short on the seat motor.
I will let you know later in the morning if it lets a reset.
Al
Old Mar 25, 2007 | 08:56 PM
MissionV1's Avatar
4th Gear
Hi Mike
I couldnt get access to net this morning. it seems I have missed you on line. call me when you can or leave your number and i will call you. The battery drain didnt work I tried a second time with both terminals off but still no luck. the radio fortunetly still works.
Talk soon
Al
Old Mar 25, 2007 | 09:12 PM
Here's the independents I know of. The first one is pretty much Rovers only. The second is a lot of everything British.
British4x4......http://www.british4x4.net/
and
Land Rover & Jaguar Service by British Performance
25800 Jeronimo Rd # 601
Mission Viejo, CA 92691
(949) 457-0680
Old Apr 6, 2007 | 09:24 PM
Jaicon's Avatar
Al, had the same problem with my unit. Turns out I pulled the seat contoller from the console and pulled it apart. do this very carefully as there is lots of springs and detent shafts that will fall out. The seat belt clasp pushed against the seat adjuster and generated enough heat to melt things and create a short. Had to buy a new seat controller from Land Rover, plug and play all is good. Note that there is two seat controllers on ebay for $33 bucks.
NESkier
Mar 1, 2015 06:59 PM
tbarton
Jul 6, 2013 02:39 PM
Newfie Rider
Mar 10, 2011 03:16 PM
MissionV1
Mar 24, 2007 10:06 PM
dailyuser
Dec 31, 2005 06:22 PM
