Sponsored by: CARiD
shift assembly
Old Sep 22, 2009 | 08:20 PM
lbishop1980's Avatar
3rd Gear
Default shift assembly
I have been having the common problem of getting stuck in park with my 03 disco. I searched this forum and decided that the brake light switch needed to be replaced. I took it in to have this done and was told that the shift assembly needed to be replaced for $622. The technician says that the brake light switch is starting to fail but that even when engaged there is no power going to the solenoid. Does this sound like a reasonable explanation? I'm inclined to just replace the brake light switch and see if that works.
Please help.
Old Sep 28, 2009 | 12:37 PM
3rd Gear
Default Please help
Does anyone out there have an answer for my problem?
Old Sep 28, 2009 | 03:32 PM
You need to post tech questions that you want replys on, in the Discovery Section where they will be seen.
You also need a second option only after you buy a new brake switch and install it, $25 in parts and 5 minutes of your time, this shop saw you coming?
Old Sep 29, 2009 | 02:12 PM
3rd Gear
Thanks
importdave
Sep 25, 2014 10:18 PM
Chrisinhouston
Nov 9, 2009 01:37 PM
masonstewart
Jul 17, 2006 02:32 PM
mcbenavidez
Dec 7, 2005 06:53 PM
Avgrognet
Nov 30, 2005 02:40 PM
