Sponsored by: CARiD
Shifter stuck, brake fuse 2002 Disco 2
Old Apr 10, 2015 | 05:04 AM
Sebc's Avatar
6th Gear
Default Shifter stuck, brake fuse 2002 Disco 2
New Disco owner here, thought I would post a possible culprit for what starts off as a stuck shifter and a brake fuse that keeps blowing. After disconnecting the brake pedal switch, shift solenoid and glove box light (just in case) the fuse was still blowing when I jumped the connector on the brake switch. I went to check for loose wires, rubbing etc. on the factory tow connector rear of the vehicle. Didn't see any damage but when I opened the door on the tow connector I noticed quite a bit of moisture on the brass connectors. We had recently had quite a bit of rain so I took the sucker apart. Full of water and corroded don't know how it lasted so long, problem solved no more short.
Old Apr 10, 2015 | 05:46 AM
drowssap's Avatar
very good catch
Old Apr 11, 2015 | 09:30 AM
Sebc's Avatar
6th Gear
Smile
Wanted to add I did replace the brake switch as well and a day later the fuse started blowing again. I removed both tail lights/stop lamps and when I removed the light on the back door there was a loose piece of metal in the bulb socket, this was shorting out the circuit. All is good now and bonus my cruise control works now!
oljohnboy
Sep 23, 2014 02:34 PM
ImQuattro
May 1, 2014 08:36 PM
Blakesrover
Feb 21, 2013 01:43 AM
pegnjared
Feb 4, 2013 07:11 AM
smyevich
Aug 31, 2006 01:31 PM
