Sponsored by: CARiD
Sirius XM not working
Old Dec 23, 2018 | 12:27 PM
beautybiz's Avatar
8th Gear
Default Sirius XM not working
Hello,
I have a 2008 RR ... I subscribed to Sirius radio but my stereo will not receive the signal. Does anyone have any insight on why? The screen says no subscription and gives the phone number to call and the ESN #. Is there a software update needed?
Old Dec 24, 2018 | 05:12 PM
ca*rovertech's Avatar
Its possible that your Satellite Radio Module is offline. It is the mini computer that controls the functions of satellite radio. It may possibly be recovered by a software update but more often than not, it may end up requiring replacement. A qualified Rover repair shop or a visit to the dealer should give ya some answers.
Old Dec 24, 2018 | 05:16 PM
Another tip: pull off the left rear luggage compartment panel and that gives you access to the stack of "infotainment" modules. Look closely to see if you have water spots on those modules. If you do, then suspect the satellite radio module has failed due to water leak into that area. Pretty common issue
Old Dec 27, 2018 | 01:10 PM
beautybiz's Avatar
8th Gear
Thanks! I unplugged and plugged back in all the modules ... now I get channel 184 but signal still not acquiring and no audio.
Old Dec 27, 2018 | 06:18 PM
Maybe contact Sirius/XM and have them reset the signal to your vehicle. See if that helps.
Old Dec 27, 2018 | 06:22 PM
beautybiz's Avatar
8th Gear
Yeah I did that but it didn’t work. You mentioned before water damage and now that I look a little closer I think it has been exposed to water . I bought a used Sirius receiver for RR on EBay thinking that may work.
Old Dec 28, 2018 | 09:16 AM
Cool, make sure to write down the ID number on the replacement receiver, and you have to register it with Sirius
Old Dec 28, 2018 | 09:26 AM
beautybiz's Avatar
8th Gear
Thanks for all of your help!
Old Jan 5, 2019 | 08:27 PM
beautybiz's Avatar
8th Gear
Sooo..I plugged in the new receiver and about 5 min later the screen on the radio went black and my battery drained completely!! I put a charger on the battery and it started right up but about 15 min later dead as a door nail again!🤯 it’s also doing crazy things like dash lights going on and off and windshield wipers go on by themselves.. HELP!! 😫
Old Jan 27, 2019 | 03:01 AM
Mrbuttchin's Avatar
That sucks....
