Sponsored by: CARiD
solved fuel pump relay popping?
Old Dec 19, 2007 | 08:36 PM
roverrick's Avatar
Default solved fuel pump relay popping?
I was poppy fuel pump relay in wet weather. after searching I stopped and went back to the basics I replaced cap and rotor it looks like i solved the problem. When it was trying to start it ,it appears the relay would over load. It has been good for 2 + weeks.
Old Dec 20, 2007 | 06:24 AM
Default RE: solved fuel pump relay popping?
Good to know you are not having a problem, but that shouldn't have been the cause of your relay popping. For a relay to start acting up, the fuel pump has to be drawing more amps like when it is about to fail, or the relay is starting to go, which is common for Rovers.
Old Dec 26, 2007 | 02:28 PM
roverrick's Avatar
Hey Mike . I don't know the connection but it seems to have solved the problem. Wehave had rain and snow and so far so good Rick
bleizit
Jun 24, 2020 04:03 AM
Travelor
Sep 24, 2015 06:11 PM
RicketyTick
Jun 24, 2014 06:58 PM
coldstart
Mar 9, 2014 07:08 PM
s10lowrider1994
Oct 6, 2011 01:22 AM
