Sponsored by: CARiD
Source for wheel caps? (solid axle)
Old Nov 11, 2020 | 12:00 PM
nathanb's Avatar
Default Source for wheel caps? (solid axle)
My rover has recently decided to shed wheel caps. I lost 4 out of 5. These are the caps that fit alloy Land Rover wheels for Defenders, RRC and D1. I see genuine for sale from $12.95 to $14.95 each, or about $10 each on eBay. Isn't there an All-Makes or Terrafirma version or something?
I never take them off. I just take the whole wheel off. So I guess I'm going to epoxy them on or something.
I see ANR2391MNH is 75mm. Do Mercedes 75mm caps fit? Because there are tons of inexpensive aftermarket ones.
Old Nov 12, 2020 | 04:27 AM
JUKE179r's Avatar
The 4 caps for my Disco 2 hubs were £30 ($40) off of eBay UK. Great quality and detail which are 62.24mm (2.45").
Old Nov 12, 2020 | 11:05 AM
nathanb's Avatar
Thank you. Those are for the D2/P38 wheels. I realized what I need is for the RRC, D1 and Defender wheels. They're 75mm OD and the clip is about 68mm. The Mercedes size is 75mm and 69mm. I ordered some and will see if they fit by the end of this week. They were $18 for set of 4 -- just ABS plastic with no logo. I will use the same paint that is on my wheels.
Old Nov 13, 2020 | 11:48 PM
nathanb's Avatar
I received the caps today and they fit quite well indeed. They have larger plastic tabs and a circular metal spring that should retain them on the wheel better than the short plastic nubs on the OEM caps. I'm not intending to advertise them here, but if anyone finds this in search, they're 75mm OD caps with 69mm ID, aftermarket intended to fit Mercedes SLK, GLK, etc. They fit the 16" RRC, D1 and Defender alloy wheels.
Old Nov 14, 2020 | 08:59 AM
Best4x4's Avatar
Post a Pic!
redrover75
Oct 28, 2020 03:02 PM
merebel
Jul 8, 2020 07:40 PM
peterboz
Range Rover Evoque
Sep 4, 2018 02:41 PM
scader
Apr 26, 2016 08:22 AM
SuperiorCarCare
Detailing
May 16, 2014 09:12 AM
