Sponsored by: CARiD
Sputtering
Old Mar 19, 2007 | 11:54 PM
Luxor's Avatar
6th Gear
Default Sputtering
I sure need some help. My '98 Disco is sputtering and stalling as if it isn't getting any fuel. I changed the fuel filter,didn't help. Thought it might be my fuel pump so I put a new one in and again, no change. So I began to look at my ignition wires and they seemed old so I put new wires and plugs in and still it sputters when I try and take off. The engine seems fine, no check engine light . My next thought is the coil. Am I taking the next logical step here? Is there any test I can do before I spend anymore on this?
I would appreciate any help.
Lux
Old Mar 20, 2007 | 12:46 PM
Default RE: Sputtering
Check and possibly replace the fuel pump relay.
Does your truck do this both cold and hot, how is the idle?
Mike
Old Mar 22, 2007 | 11:42 AM
Luxor's Avatar
6th Gear
Mike, thanks for the help. I did check the relay and eventually found the problem to be in the coil. I found a used coil block for $275 and the Rover is running better than ever. It was probably time to change my ignition wires and plugs anyway. So my saga is complete. I will definitely use this forum again.
Take care, Greg
Old Mar 22, 2007 | 12:37 PM
Consider using the Magnaco 8mm plug wires, they are really great and hold up well on Rovers.
Mike
Lnghrn Disco
Jun 5, 2007 10:55 AM
Rover9
Feb 23, 2007 04:34 PM
Charlie L
Jan 7, 2006 10:26 AM
Charlie L
Dec 8, 2005 02:41 PM
JA-NH
Jan 22, 2005 08:32 AM
