Sponsored by: CARiD
Starter Motor and Horn Stuck On
Old May 19, 2008 | 10:15 PM
mkt's Avatar
mkt
3rd Gear
Default Starter Motor and Horn Stuck On
I am new to the forum and need soon help:
I have a 200130th Anniversary RR since new with only 20K miles. 3 weeks agothe horn and starter motor turned on suddenly and stayedon when thewife was driving it on a rainy afternoon. Turning the ignition offwouldnot stop the starter and horn(the wiper and lights were on also but I am not sure if the wife have acutually turned them on while she was driving it) - I have to disconnect the battery cable to turn off everything. I tried reconnecting the cable 30 minutes later and the same happened - starter and horn came on with the ignition still in the off position.
Have the car towed to the dealer immediately. The service manager called the next day and saidthey could not find anything wrong with the car - all electricals are working. The dealer has had the car for 3 weeks now and still couldn't find anything wrong - they have driven the car extensively and spayed water over and under it to try finding the problem - No luck. One tech said that the problemMAY have been cause by a (temporary) faulty Body Control Unit (???)
I do a have an extended warranty but they would not pay for the Body Control Unit replacement unless it is actually found to be faulty.
Can someone help please? Have anyone experienced or heard of similar problem?
Old May 19, 2008 | 10:27 PM
roverguy7's Avatar
Default RE: Starter Motor and Horn Stuck On
with both of them going off at the same time, it sounds a little more like a short, both have relays in the engine fusebox, if you get a short to ground on the control wires, or even inside the fusebox, it can cause an intermitant issue like this. might be a pain, but drive it til its doin it all the time, let your ext warr take care of the fuse box and new starter and flywheel, cus theyll be chewed up
Old May 19, 2008 | 10:38 PM
mkt's Avatar
mkt
3rd Gear
Thanks roverguys7.
I toldthe dealerto check the relays and the wiring in the steering column for shorts - the dealer said they did and find no issues. I'll ask them again tomorrow.
The problem is its my wife's car and I travel a lot. Immagine the horn goes off in the middle of the night when I am not home......
Thanks again.
Old May 19, 2008 | 11:31 PM
WolfPack's Avatar
That's quite a problem to have! It's been my experience with Rover repairs that when the shop/dealer can't pin point the problem, they tend to lean on the Body Control Module as the source. Seeing as how just about everything on the body runs through the BCM....it makes sense....but with the cost of it, I still classify it as a last resort[&o]
Old May 20, 2008 | 12:23 AM
mkt's Avatar
mkt
3rd Gear
Wolfpack,
Are the starter motor and wipers relays controlled via the Body Control Module? Or are they just hardwired to the respective switches? For an older car likemy 2001 RR, I would guess that the relays are not controlledvia a control module. Of cause I could very well be wrong.
Old May 20, 2008 | 02:15 PM
Charles68's Avatar
With our 2001 Disco II, the horn sometimes starts blaring in middle of night. Its a mechanical issue. The edge of the horn button simply sticks on steering wheel after being pressed.Just a bit. Then at night - I'm not sure if moisture/humidity is the issue, the connection will be made and it starts blaring. The first time it happened I couldn't figure out what it was...
Old May 23, 2008 | 06:33 PM
roverguy7's Avatar
yes they both go through the BeCM, but whats this about the wipers now?
bagocheetohs
Aug 25, 2014 07:25 AM
Gimebakmybulits
Jul 14, 2014 05:57 PM
ImQuattro
May 1, 2014 08:36 PM
johnkbl
Apr 23, 2012 07:49 PM
lipadj46
Aug 13, 2009 07:47 PM
