Sponsored by: CARiD
Starting Problem
Old Oct 7, 2009 | 03:04 PM
gcredlon's Avatar
Default Starting Problem
96 Land Rover Discovery, Rpm's wouldn't climb above 1800 rpm's no codes, no check engine light. I knew it was the crank shaft sensor, pulled it out the needle got struck and was bent over 90 degrees, replaced the sensor and i'm going to replace the flywheel tomorrow when it arrives, now the Rover cranks over and won't start at all checked the plugs a little fuel on them, not the fuel cut off switch either. Put pressure gauges on the cylinders pressures fine. btw still no codes and no lights come on. Fuel pumps working and its getting good spark. Somebody Please Help?
lazerbrains
LR2
38
Aug 9, 2023 07:54 PM
djaaronreed
Dec 7, 2013 11:01 AM
brian.arthur
Freelander
Mar 14, 2006 04:32 PM
finetrophywife
Aug 2, 2005 01:43 AM
asmcmillin
Apr 10, 2005 12:16 AM
