Still Miss fire code after changing plugs
Hi Everyone.
Tried the self help; read thru the threads after getting p0302 and p1319 codes.
I have a disco 2003 with 130,000.
I still have the codes after changing the spark plugs and wires.
What do I do next? Really need help. Bought the car about a month ago.
Hopefully this helps someone. If you replace the wires and plug and you still have engine misfire, check to see if u have sparks through the wires coming from the ignition coil. No spark? Your coil is bad. Check used parts first before u spend $400.
You can not change your coils without removing your manifold. The will fix your issue. Mine is fixed.
