Sponsored by: CARiD
Still Miss fire code after changing plugs
Old Oct 24, 2010 | 06:23 PM
shoo's Avatar
6th Gear
Default Still Miss fire code after changing plugs
Hi Everyone.
Tried the self help; read thru the threads after getting p0302 and p1319 codes.
I have a disco 2003 with 130,000.
I still have the codes after changing the spark plugs and wires.
What do I do next? Really need help. Bought the car about a month ago.
Old Oct 24, 2010 | 06:54 PM
What brand of wires and plugs did you install? What octane gas are you using?
Old Oct 24, 2010 | 07:35 PM
shoo's Avatar
6th Gear
Used high octane since I bought the car.
I checked and there is no spark from #2 wire coming from the coil. Could my coil be bad?
I had code before and after changing the plugs and wires.
Old Oct 25, 2010 | 07:20 AM
Don't make me work so hard and answer all my questions.
Old Oct 25, 2010 | 07:41 AM
shoo's Avatar
6th Gear
LOL
There's no name on the wire box I got from Miami Rover but he said the were one of the best after market. I got autolite platinum plugs. 93 octane gas in tank.
Old Oct 26, 2010 | 08:00 PM
shoo's Avatar
6th Gear
Hopefully this helps someone. If you replace the wires and plug and you still have engine misfire, check to see if u have sparks through the wires coming from the ignition coil. No spark? Your coil is bad. Check used parts first before u spend $400.
You can not change your coils without removing your manifold. The will fix your issue. Mine is fixed.
Buzz09
May 8, 2010 04:21 PM
tommytwotone
Oct 26, 2009 10:59 PM
mitsi88
Mar 26, 2008 08:51 AM
allstarbiker592
Mar 14, 2007 11:41 AM
04DISCOINHR
Feb 28, 2007 12:05 PM
