Aside from the issue with the input gear needing to be swapped has anyone given this a go I’m not factory fuel injected so I don’t know that clearance will be an issue
Can confirm the clearance is an issue. With the intake manifold front bolt and the gear being incorrect. Now I am trying to sort out if it will work with grinding
