Sponsored by: CARiD
Suspension fault - odd symptoms LR3 2006
Old Apr 27, 2016 | 10:25 AM
jophess17's Avatar
Default Suspension fault - odd symptoms LR3 2006
I am getting the suspension fault light and message. It only happens when the the LR3 has been sitting idling for a few moments and not every time it sits and idles. Does not happen when driving or using the terrain select. I am thinking a ride height sensor is going bad but it is not showing its face. It has been doing this a couple of months. Please help
Old Apr 27, 2016 | 10:27 AM
jafir's Avatar
You'll need to pull codes to see what the fault is.
Old Apr 27, 2016 | 01:01 PM
sleepercoupe's Avatar
Codes.
-Compressor too slow to fill is the most likely. Ive only replaced one sensor in all the LR3s Ive worked on and it was usually not always but a front strut and an update to the compressor design.
DPM LR3
Jan 13, 2016 11:19 AM
06Range
May 8, 2013 09:01 PM
anhernandez
Aug 18, 2009 12:47 AM
