SUSPENSION HELP PLEASE!!!!!
I have an 05 RR and while driving today heard a beep looked down at message center and it said air suspension inactive. And no lights on height indicator. It continued to go on and off. Got it home let truck cool down and after about 20 min of driving did it again. Called the place I purchased it and drove it to them and it was fine for another 20 or so then went out again. The ride height never seemed to change, it only felt stiffer. Its at the dealer just wondering about what the problem could be. Any input will be great.
RE: SUSPENSION HELP PLEASE!!!!!
Hey I just want to thank those 44 people who viewed this for not responding. Turns out that it was a fault with computer, possibly a slow leak with one of the airbags. But no worries all is well so far. Again thank you to those 44 peoplr for their input it was invaluable.
on
Since no one had any idea what was wrong with your truck, based on little or no specific information from you, it wouldn't have done much good for anyone to reply to something they didn't have a clue about.
If you don't like the waqy things work on this site, there are other sites out therefor you to try.
Mike
Mike
It's kind of hard to determine what it can be thats causing your RR to do this, but a few things I can possibly suggest to look at are the following: Height Sensors, Leak in one of your air-hoses, or simply you need to have your Air Suspension System reset by the Certified Tech or LR Dealer with the right equipment (Computer Scanner) that allows you to read the air suspension. Lastly, if that "Air Suspension Inactive" displays again after you turn on your vehicle, simply pull up the emergency brake, close all the doors, and turn the steerring wheel as counter clock-wise, (all the way to the left), and then clock wise, (all the way to the right), then center it once again. That should take away that indicator for the "ASI" from lighting up again.
whurst79
01-28-2013 09:24 PM
ChadEvans
03-27-2008 04:01 PM
