Sponsored by: CARiD
SUSPENSION HELP PLEASE!!!!!
Old Feb 3, 2009 | 04:47 PM
msk2503's Avatar
Default SUSPENSION HELP PLEASE!!!!!
I have an 05 RR and while driving today heard a beep looked down at message center and it said air suspension inactive. And no lights on height indicator. It continued to go on and off. Got it home let truck cool down and after about 20 min of driving did it again. Called the place I purchased it and drove it to them and it was fine for another 20 or so then went out again. The ride height never seemed to change, it only felt stiffer. Its at the dealer just wondering about what the problem could be. Any input will be great.
Old Feb 12, 2009 | 10:55 PM
msk2503's Avatar
Default RE: SUSPENSION HELP PLEASE!!!!!
Hey I just want to thank those 44 people who viewed this for not responding. Turns out that it was a fault with computer, possibly a slow leak with one of the airbags. But no worries all is well so far. Again thank you to those 44 peoplr for their input it was invaluable.
Old Feb 13, 2009 | 04:22 PM
Since no one had any idea what was wrong with your truck, based on little or no specific information from you, it wouldn't have done much good for anyone to reply to something they didn't have a clue about.
If you don't like the waqy things work on this site, there are other sites out therefor you to try.
Mike
Old Feb 24, 2009 | 10:52 AM
mattkon's Avatar
4th Gear
Default 45
wow, would you rather have 44 people tell you 44 different things that are wrong with range cause they have no idea whats wrong with it?
Old Feb 10, 2011 | 11:11 AM
NhudeST's Avatar
It's kind of hard to determine what it can be thats causing your RR to do this, but a few things I can possibly suggest to look at are the following: Height Sensors, Leak in one of your air-hoses, or simply you need to have your Air Suspension System reset by the Certified Tech or LR Dealer with the right equipment (Computer Scanner) that allows you to read the air suspension. Lastly, if that "Air Suspension Inactive" displays again after you turn on your vehicle, simply pull up the emergency brake, close all the doors, and turn the steerring wheel as counter clock-wise, (all the way to the left), and then clock wise, (all the way to the right), then center it once again. That should take away that indicator for the "ASI" from lighting up again.
Old Feb 10, 2011 | 11:27 AM
hilltoppersx's Avatar
i never saw this thread, its posted in the wrong section.
Old Feb 10, 2011 | 05:19 PM
Chris-bob's Avatar
I bet it was a fault with computer, possibly a slow leak with one of the airbags.=)
yozzer
Aug 2, 2011 05:40 PM
New2LandRovers
Jul 15, 2011 12:23 PM
ChadEvans
Mar 27, 2008 04:01 PM
cold_surfer
May 9, 2007 08:23 AM
