Sponsored by: CARiD
suspension L322
Old Jan 9, 2018 | 01:56 PM
john hennessy's Avatar
5th Gear
Default suspension L322
hello everyone and all,
i have a very strange problem with my suspension.
2003 L322.
after disconnecting the battery i now have no suspension operation, no lights on the control panel and NO MESSAGE in the information center.
i scanned with all comms, it says "ecu fault".
fuse 57 is hot and so is fuse 18 and the relay seems o.k.
the fuse box lid shows a fuse 88, where would that be located?
so if indeed there is an ecu fault and the code doesn't clear and it won't what do i do next?
if i buy another ecu for the EAS, will this need configuring and if so how
Old Jan 11, 2018 | 12:29 AM
5th Gear
EAS ecu not functioning was due to a bad body ground at the battery box, i cleaned the ground and i could clear the DTC and then it all came back to life.
molly
Jun 12, 2020 01:34 PM
will.tillery
13
May 21, 2016 08:16 AM
electriceddy84
Oct 29, 2013 09:52 AM
Savannah
Sep 16, 2008 08:35 PM
mitchellporritt
Oct 9, 2007 12:18 PM
