Sponsored by: CARiD
Swivel Fluid....yes, read other posts...
Old Jun 27, 2011 | 01:13 AM
wheelgarage's Avatar
Default Swivel Fluid....yes, read other posts...
Okay, I read other post and forums on this subject. And from my recollection of my last Disco, I had them resealed and filled with the "grease packs", when the driver side swivel leaked.
Reading though the RAVE fluid requirements, it stated that the Diff and Swivels can use the same fluid.
So, my plan is to service them next week, using what I used on the Diffs, Redline 75w/140. I did read that if the swivels seals are good there shouldnt be any issues. But, I read that it can begin to leak from old seals. This Disco has 117k and does have any of the leaking housing.
My concern, should I really be worried?
Old Jun 27, 2011 | 12:43 PM
Okay, did more research today and read that the old swivels, like mine, are fine to use the same gear oil.
Since I have the drain, level and fill holes, then using gear oil will be an easy job.
Just hope they dont leak. Well, if they do, it will be a good excuse to rebuilid them.
Old Jun 27, 2011 | 04:51 PM
Banzai Jimmy's Avatar
I tore down one side recently and didn't have a one-shot of grease handy, so just tossed in gear oil. It's weeping a little bit, but not gushing or creating a puddle on the ground. I'll go back to grease, once I get off my lazy butt and buy some more, just to have it be leak free. I'll likely buy the grease when I end up with a big leak.
collin Barrows
Audio/Visual Electronics
Aug 21, 2011 12:47 PM
maroonbully99
Feb 26, 2010 05:01 PM
chakadog
Apr 11, 2009 02:49 PM
NYChasNOtrails
May 12, 2008 10:00 PM
tskeltonPGA
Jan 16, 2008 07:21 PM
