Sponsored by: CARiD
Swivel Housing question, please help!
Old May 22, 2010 | 02:22 PM
CUpgt's Avatar
Default Swivel Housing question, please help!
Ok, so I recently bought a 98 Disco and I have been going over the whole vehicle trying to make sure to do all the needed maintenance work. I am pretty sure that one of my swivel housings is pretty close to bone dry while the other one appears to be moderately lubed. I have done quite a bit of searching and am about 99.9% positive that LR had gone to grease in the swivel housing and done away with the level and drain plug. I found the fill plug right away but now i have no idea of telling how much grease to add to each housing. Any input would be greatly appreciated. Thanks guys
Old May 22, 2010 | 04:56 PM
aemnky606's Avatar
on the same side as the fill plug there is a drain plug. drain all the oil out of both hubs and add one tube to each hub. You will be set to go.
http://www.roverparts.com/Parts/STC3435G.cfm
Walter
Old May 22, 2010 | 08:54 PM
WIS ROVER's Avatar
Apparently 98s and 99s (and maybe 97s) don't have drain and level plugs. I guess you just keep it topped off with grease?
sclarkie
Sep 6, 2011 11:38 AM
herblatham
Aug 18, 2010 09:25 PM
robot808
Dec 8, 2009 07:32 PM
mburnett
May 28, 2007 09:18 PM
