Sponsored by: CARiD
TC light on a 2003 Disco II
Old Apr 16, 2021 | 09:41 PM
Jon.P's Avatar
Default TC light on a 2003 Disco II
TC light keeps coming on and got it diagnosed with an Iland. This was the code that came up. What would you work/change?
Old Apr 16, 2021 | 10:50 PM
Shiftonthefly1's Avatar
Do a thread/google search this subject has been covered ...a ton.
You have two options bypass or replace the shuttle valve. Lots of of videos on it. Either repair isn't that hard to do. You can do it w out bleeding brakes.
Old Apr 17, 2021 | 07:31 PM
Jon.P's Avatar
so disclaimer I am a new discovery 2 owner and still learning this stuff.
I do not have the three amigos lights on just the TC light.
I have done some researching and see that I can replace the switch which should be within the realm of my ability.
I am now starting to see some information on option B which does some kind of bypass on it and is probably outside of my ability.
since I only have the TC light on and not the three amigos I was wondering if anyone had any better information on what might be causing this. It seems that all the threads you were speaking of have to do with the three amigos which I do not have.
Old Apr 18, 2021 | 06:29 AM
mollusc's Avatar
Whether or not you have the full three amigos, you have an indication of a shuttle valve switch failure. This points to you needing to service the shuttle valve switch module.
Option B is just as easy as replacing the switch. The hardest part of either operation is to get the switch module out of the valve block.
Old Apr 18, 2021 | 06:25 PM
I get that. I'm sorry if my tone sounded short. I was simply saying if you do a search you'll probably have more information than you want. Not in a ****ty way.
Just like it was said above you've got a malfunctioning shuttle valve. 10mm bolts at the base and releasing the brake lines from thier holders near the wipers. That way the unit can move a bit. It's an allen head underneath I think 4mm. I could be wrong.
Old Apr 18, 2021 | 06:37 PM
Jon.P's Avatar
ok cool thanks! I’m going to start with this it seems to be the consensus. So you did not take off your brake lines, you just took them out of the mounts by the wipers?
Wondering if I should just switch the switch out first to a new one and see if that solves it and if not then I’ll do the option B modification.
Old Apr 19, 2021 | 06:25 AM
That's correct. No actual brake line removal. It requires you to loosen the tiny screws blind and upside down. But in my opinion it's better than bleeding brakes.
What you see laying on the towel in my pic is the new part you'd get if you ordered one. It's a plug in unit w two wires going to it. Getting the cover off the ABS unit is the hardest bit.
Lil Beast
Dec 30, 2017 09:36 AM
2003Freelander
Nov 30, 2017 04:34 AM
Hul1gan
Sep 27, 2016 09:10 PM
jmt
Jan 22, 2008 04:34 PM
CrimeScene
Jan 20, 2006 02:08 PM
