Sponsored by: CARiD
tdi 1998 disco fuel pump and injectors
Old Jul 28, 2016 | 05:50 AM
dif3's Avatar
Default tdi 1998 disco fuel pump and injectors
upon having a reco ingin installed after 4 years of saving
the machic who installed the motor and assembled all inadvertently some how installed radiator hoses incorrectly after 30 mitutes of id-eliding his assistant went for test drive 2k eng hot 2 1/2k red line 2 1/2k back over hills steam and then hose down
my problem is now fuel pump and injectors
he states 4 years off storage causing execs fuel and smoke from exhaust
another diesel person said cooked injectors and fuel pump not repairable
the correct answer please
with thanks Allen Ka bris aust
Old Aug 2, 2016 | 07:32 AM
loanrangie's Avatar
Some mechanic if he can get hoses mixed up, not many if any TDI's in the US so you would be better asking on AULRO, i have had my 98 TDI for 10 years and almost 170K.
It may be the valve stem seals have dried out or could be worn turbo shaft causing excess smoke, you need to determine if its oil being burnt or running too rich.
Madlands
Feb 10, 2016 09:54 AM
Offer2603
Jun 22, 2013 09:27 AM
Offer2603
Jun 18, 2013 09:01 PM
Offer2603
Jun 18, 2013 03:08 PM
tbraith
Jan 15, 2008 01:24 PM
