Sponsored by: CARiD
Tempermental
Old Jun 13, 2014 | 11:53 AM
Linda Weeks's Avatar
Question Tempermental
The Rover will be running fine then it shuts off and won't start again. Nothing electrical will work after it shuts off too. What is wrong with it?
Old Jun 13, 2014 | 02:14 PM
dusty1's Avatar
a little more info might help. '83 110 or '14 range rover sport? upon the event does it try to start, click, or?
Old Jun 13, 2014 | 02:30 PM
95 Discovery, nothing happens not even a click when you try to start it. The battery is fine. Then you try to start it the next day or a month later and it starts.
Old Jun 14, 2014 | 10:57 AM
dusty1's Avatar
well outta my realm (that doesn't take much) i think 95 still has a distributor (there goes ckp theory but the electrical part sounds like a wire shorting)
but here is a bump. maybe the weekend crowd will chime in with some ignition switch theory,sensor, or something.
for more info; do you have a check engine light on? codes?
when it dies, does it shutter or just cut off like it thinks the ignition has been turned off? any correlation with the episodes and water related events (car wash/rain)?
Old Jun 14, 2014 | 11:27 AM
MonteroMan's Avatar
Default Similar
Read my post under Discovery 1 (to Discovery Mike) - and do this test: do not lock your vehicle at all after the last drive and then start as normal the next time.
After reading the silly number of starting problems with Discovery I and II I believe that the alarm system / immobiliser is the main culprit. After two months of continual problems I have now a little experience of this.
A.
jared
Feb 11, 2008 10:02 AM
