Sponsored by: CARiD
Throttle body leaking...NO more
Old Oct 8, 2019 | 04:43 PM
binch's Avatar
Banned
Talking Throttle body leaking...NO more
One of the banes of my Disco 11's exisitence has got to be the stupid throttle body heater! I have been through at least 3 of them as they would always start leaking when the leading edge of the heater plate (where the inlet and outlet tubes enter) would warp and start to leak. I tried using different gasket materials, snugging the screws up, reefing the up tight, etc....but the end results were always the same!!! A warped leading edge and frustration....all because of a poorly designed part by LR! Well I think I've found a workable solution to my problem.....my local shop looked at the problem and came up with their own solution and built a much beefier, Heavy duty throttle body heater plate. I've had it on for a while now and I think it will definitely outlast the truck too! The made the plate MUCH thicker and a bit longer, allowing for far more material between the inlet and outlet pipes, so warp will not be an issue now.
Here's a link to their site
https://www.sportscarcentre.ca/MGM000010K?mid=948
Old Oct 9, 2019 | 04:19 AM
JUKE179r's Avatar
Anybody who is still fabricating parts to better our aging Land Rovers is graciously welcomed. Cheers!
Chrisinhouston
Mar 8, 2020 03:54 PM
aguison
Jul 15, 2014 03:57 PM
wynhd
Nov 21, 2013 10:40 AM
Daymeon
Sep 10, 2009 01:12 PM
humroot
Mar 21, 2008 01:55 PM
