Sponsored by: CARiD
Throwing codes
Old Jan 4, 2007 | 01:47 PM
MyRover01's Avatar
Default Throwing codes
Checked whcih codes my Rover was throwing and here is what came up.[:@]
P0734-Incorrect 4th gear
P0150-02 Sensor
P0174-Very rich or lean
P1174-Manufacturer code have no idea what that is
P0159-Very rich or lean
How would i go about fixing all of this. I'm pretty sure this is all being caused by just an o2 sensor but i could be wrong. Any help is appreciated.
Thanks,
-Terry
Old Jan 4, 2007 | 02:54 PM
Default RE: Throwing codes
What year, model and mileage?
Mike
Old Jan 4, 2007 | 03:01 PM
MyRover01's Avatar
00 Discovery II 76kmiles
Old Jan 4, 2007 | 05:34 PM
Terry,
How is the truck running, do you use high octane gas, how is the truck shifting, does the exhaust smell ba?
Mike
Old Jan 4, 2007 | 06:12 PM
MyRover01's Avatar
It drives and runs fine although does smell a little like the cat is going bad. The way it shifts is weird because 3rd gear don't shift until 51 mph. The gas mileage is still 250 per tank using 91 with a bad o2 sensor. And it does vibrate a little at stop lights then goes away shortly after.
Old Jan 4, 2007 | 07:09 PM
OK,
Doesn't fit the normal seniero but I believe you have 2 problems, bad O2 sensors on Bank and a failing MAF.
The Maf would be causeing a bad smell, tranny shifting problem and MPG drop.
Send me a private message with your tele number and a good time to call and I would be glad to cal you and talk you thru this.
Mike
Old Jan 4, 2007 | 07:41 PM
MyRover01's Avatar
Thanks for the help! Now the next thing would be where should i get these parts? Because i know if i go through the dealership its going to cost a pretty penny.
Thanks,
Terry
Old Jan 4, 2007 | 09:53 PM
Send me your tele number and we will talk or call me in Colo at 303-862-7680
Mike
Soccer Dad
Jan 27, 2011 09:49 AM
greg409
Aug 16, 2009 08:05 PM
NM-DiscoDuck
Jul 31, 2009 12:07 AM
WolfPack
Feb 13, 2008 08:49 PM
Kraftyz51
Oct 24, 2007 03:06 PM
